Corvette Rotors
Old Dec 29, 2007 | 11:07 AM
71-Camaro-98's Avatar
Default Corvette Rotors
So I know that Corvette calipers will bolt right on my 98 Camaro but will I be able to use corvette rotors as well or do I have to modify to do that?? Thanks.
Old Dec 29, 2007 | 11:33 AM
robertbartsch's Avatar
C5 rotors are 1 inch larger so you cannot bolt these on an F-Body without other modifications.
The F-body calipers have larger pistons then the C5 so they have more clamping force. The c5 calipers are a tad stronger, however.
I went with aftermarket brackets allowing me to run C5 rotors and f-body calipers.
Frankly, this was a waste. If you experience brake fade with the f-Body brakes then upgrade to c5 rotors. If not, just go with new f-body Brembo rotors and Hawk pads.
Old Dec 29, 2007 | 02:24 PM
socmguy's Avatar
Restricted User
yep, get the conversions brackets from UMI. Then you'll be able to run the 12.8" rotors.
Old Dec 29, 2007 | 04:02 PM
Cool, thanks for the info...
Old Dec 29, 2007 | 07:39 PM
UMI Performance's Avatar
Here is a link with some information. If you have any questions please ask.
http://www.umiperformance.com/page.php?page=c5conv
Thank you!
Ryan
Old Jan 2, 2008 | 05:18 AM
69TA's Avatar
I have some Baer C5 two piece rotors for sale
