Replaced Lower A Arm
Old Dec 30, 2007 | 12:48 PM
2000Z28M6's Avatar
Default Replaced Lower A Arm
I replaced the stock front lower A arm a while back. I have noticed that the wheel looks like its a hair closer to the wheel well on that side now.
I need an alignment but I took it to brake check and those jokers said they cant do anything about the gap and that an alignment wouldnt really help the gap.
Where can I take my car to get an alignment and have them check the lower A arm?
Old Dec 30, 2007 | 06:16 PM
35th SS's Avatar
take it to a reliable alignment shop in your area where you can trust that person about doing it.and make sure hes good at what he does.think you need your camber/caster adjusted since you are using an aftermarket lower a arms that are adjustable.good luck
