drag shocks on the street?
Thanks for the reply.... I figured it was something like that. I was just paranoid that if I ran over a big bump in the road one of them would explode or something.
He said that they shoot up quick, which is good, but that they come down just as fast and he doesn't like them. He told me to look into Koni Doub;e Adjustab;es to set the up and down motions. What do you think? Will the Hals be fine?Or are Konis worth it.
Please keep in mind that he had an M6 and I'm A4. Thanks.
If you are drag racing a lot, then get the QA1's.(Hals). The CE rear drag shocks can only be adjusted in 3 positions, AND you have to take them off to adjust them.
BUT, use stock front springs do not use the QA1 springs otherwise the front of the car will be low and bottom out over big bumps. My buddy had the QA1 front springs and went back to stock and the car is like stock.
Let's look at another aspect of shocks. The QA1's are 12 position adjustable. Just get under the car and click away. Now stock shocks are 50/50. So on the street you can run your QA1's at 6 or 7 to feel like stock... You should feel the firmness of 8, pretty cool. Don't ever drive on the street for long periods of time with them at full loose you will eventually pop the seal on the fronts.
I ordered my CE rear drag shocks from Speed Inc. I haven't seen any other place that has them, I looked around. Just go to their website under the suspension components. It does suck that you do have to take them partially off to adjust them because the piston has to be compressed completely then you rotate the piston to change the setting.
There's 3 settings... 50/50 40/60 30/70 the first number indicates the percentage of force required to compress the shock compared to the force required to extend it. So that being said since I drive my car on the street a lot I set them to 50/50. That's the setting if the track is hooking perfectly the other 2 are softer which allow the rear of the car to squat more easily. I figure at the track I'll adjust my front HALS and see how I do... then if I need a little more front end lift I can take the rear wheels off, unbolt the bottoms of the shocks, push them up and twist them into the new adjustment position. Kind of a pain I guess, but they are cheaper than the HALS and the rears probably won't need to be adjusted as much as the fronts. I see the benefit of the HALS on the fronts (for drag racing) the most but thats just MO.
cancel your order or send it back and buy some strange 10 adjustable shocks from billingsley. They are just like the QA1s minus 2 settings and according to chevyguy3 about the same in weight which he finds surprising since they have a steel body compared to the aluminum on the QA1
plus they are only $60 a piece
hope this helped
