bottoming out
Old Jan 23, 2008 | 09:17 PM
slayerized6's Avatar
Default bottoming out
hey, ive had problems with bottoming out on some steep driveway inclines. it sounds as if my stock y pipe is hitting the ground when my front wheels are on the street level and rear is just about to go the driveway into the street, and vice versa. my stock suspension seems to be fine, but whats causing it to bottom out? is there anything i can do do help stop it?
Old Jan 23, 2008 | 10:21 PM
Black02SLPSS's Avatar
Are you sure its your ypipe or that air dam that directs air into the radiator? Thats what i scrape on 99% of the time.
Old Jan 23, 2008 | 10:27 PM
im 80% sure its the y pipe, its defintly a metal clunking sound. the y pipe does show some scratches, ill have to check the air dam
