Spohn adjustable T/A bolt torque question
Install went smooth as silk, pinion angle is set at -2*, and yes, it has the infamous Spohn torque arm clunk sometimes.
My question, in the picture below, how tight should that particular bolt be? Should it be torqued to any spec, tightened as tight as I can get it, good and snug, or what? All other bolts/nuts only tighten as far as the bushing sleeves will let them, but this one, when tightened as tight as I can get it, seems to cause a binding up of that pivot point.
Thanks in advance.
p.s. Don't mind the kindergarten MS Paint job of mine, lol
