Installing front springs
Just pull it forward gently and it will come off the studs on the brake booster, scoot it sideways and remove the bolts with a torx bit and a 3/8 drive ratchet. That is how mine came apart. And (thanks to Mitchintx) you should swap the torx bolts from the drivers side to the passengers side and use 2 of the regular bolts from the passengers side (that can be removed with a wrench) when you reassemble....Mitch is brilliant....Good luck!
