spring swap
Old Feb 12, 2008 | 10:01 PM
davidadavila's Avatar
Default spring swap
dont have lots of experience or cool tools but i just bought some hotchis springs and i have the spring compressor on the way...is there any install instructions around maybe with some pics i heard that the top nut on the sturut needs to be taken out with a power gun me dont have one can i do it with regular tools?
Old Feb 13, 2008 | 05:52 PM
**** i did use search button...geez no love
Old Feb 14, 2008 | 01:44 PM
chupr0kabra's Avatar
I swapped to Hotchkis springs using the spring compressors you can rent from Autozone. However, the coils are very close together, so I had to slide the blocks on where they would fit, then hammered them around until they were far enough apart to compress the spring and relieve pressure off the nut on top. I can't say I'd recommend that.
You might be able to find one of these relatively cheap:
You don't NEED air tools to get the job done, but they certainly make it easier.
-Mike
Old Feb 14, 2008 | 01:52 PM
Chevy_Man_510's Avatar
Isn't there a write up on this on ls1howto.com??? The link should take you to it...
http://www.ls1howto.com/index.php?article=6
Old Feb 14, 2008 | 02:01 PM
DopeFedZ's Avatar
Hopefully the top nut isn't rusted to the shock thread shaft. If it is prepare for war
Old Feb 14, 2008 | 02:58 PM
z28bryan's Avatar
www.ls1howto.com is great. The guy recommends a pickle fork to separate the spindle from the ball joint. I didn't need it and don't see a lot of people who did. Just smack the bottom of it up with a hammer.
Keep in mind the top shock nut is hard to remove. I was lucky and didn't need to cut it off like many have.
