LCA relocation brackets?
Old Feb 21, 2008 | 11:35 AM
xBROKEx's Avatar
Originally Posted by UMI Performance
They are different, the weld ins must be welded but the bolt ons can be welded if needed. The bolt ins tie into the shock mount to locate them and support them, the welds do not.
Weld-Ins
Bolt In's-
ohhhhh ok, i see. I accidentally bought some weld in ones from spohn and didnt realize it till just now when i saw the picture of the bolt in ones
Old Feb 21, 2008 | 06:04 PM
RAGENZ28's Avatar
Too bad most of the kits are only 2 holes, if you run a tall tire and have your car lowered you won't be able to get the angle you need.
Old Feb 21, 2008 | 08:48 PM
radz282003's Avatar
I can attest to them acting as lift bars. I've been told and have felt my rear end lift with the addition of these. I'm non-lowered and run on 255/50/16 DRs, and I've been able to pull mid-1.6s with my 3800 stall, MT DRs, 3.23s, at full 3625 lb. (without my 290 lb. a$$) with a lid, tranny tune, and catback. I think that is a pretty good 60' considering my weight and power level (I suspect around 320-330 RWHP.) I had the TA set up around -2.0*.
I hope this helps
Old Feb 21, 2008 | 09:14 PM
SSmoken's Avatar
so which is better bolt or weld in??? I have no welder or knowledge of how to weld.
Old Feb 21, 2008 | 09:24 PM
radz282003's Avatar
I've had no experience with the weld-in. I've have the bolt-in and they've worked fine for me. The car is never going to go much faster than in the high-10s (eventually) so I figure these will be just fine.
From your signature, I'm sure the bolt-ons will be just fine for ya'. I got BMR here, and they bolted in with just a little cutting to the E-brake brackets and I obtained some longer bolts for where the LCA bolts into the relocation bracket. Besides finding some longer bolts, it couldn't have been easier ;D
Old Feb 22, 2008 | 08:24 PM
BMR Suspension's Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Our bolt in relocation brackets are fabricated from the same material as the weld in so material strength is not an issue. Most people go to a weld in style relocation bracket when they choose to run an aftermarket style rearend where the bolt in relocation brackets will not work.
__________________
Allan Miller
President
BMR Suspension
www.bmrsuspension.com
(813) 986-9302
Old Feb 22, 2008 | 08:53 PM
FirebirdStud's Avatar
I thought the UMI instructions were sub-par... anyone have install instructions that are understandable? Anyone have a link or something to Spohns instructions or BMR's instructions? I have a weld in set that I am gonna try to fab into the S60 soon...
Old Feb 22, 2008 | 09:10 PM
When installing weld in relocation brackets you want to make sure you are doing it right the first time. You can reach me on Monday in the office and I can go over the procedure on the phone with you
In the mean time, here are the Install Instructions for our weld-on relocation brackets:
http://www.bmrfabrication.com/INSTALL/CAB001.pdf
Here are the Install Instructions for our bolt-on relocation brackets:
http://www.bmrfabrication.com/INSTALL/CAB002.pdf
__________________
Allan Miller
President
BMR Suspension
(813) 986-9302
Old Feb 23, 2008 | 02:24 PM
Thanks for the instruction link! I appreciate it, and I saved it. Seeing yours and UMI's makes alot more sense now...
Old Feb 23, 2008 | 06:41 PM
Arc00TA's Avatar
Just a question to add, I'm going back to my stock springs tomorrow from the sportlines I have on now due to exhaust clearance issues. I have the weld ins with adjustable LCA's set on the lower hole on the bracket. Can I leave this alone? I would rather not cut off the brackets altogether. If I can leave it do I have to adjust the LCA's out some to compensate for the extra height? Sorry if these are dumb questions been up for like 46 hours.
Old Feb 23, 2008 | 07:02 PM
You should be able to leave them at the same setting no problem.
__________________
Allan Miller
President
BMR Suspension
(813) 986-9302
Old Feb 24, 2008 | 12:40 AM
  #32
SSmoken's Avatar
aight, thanks for the input bud.
well as soon as I win that free torque arm I'll probably try a set of these out
Old Feb 24, 2008 | 09:28 AM
  #33
linegtdt52's Avatar
will your relocation brackets fit a moser 9"
Old Feb 24, 2008 | 09:34 AM
  #34
linegtdt52's Avatar
Default brackets
also do you offer a bolt in and a weld in for the 9"
Old Feb 24, 2008 | 09:43 AM
  #35
UMI Performance's Avatar
Hello,
You would need a set built specifically for the Moser rear end, they can be here- www.umiperformance.com/2011
If you have any questions please ask. Thank you!
Ryan
Old Feb 24, 2008 | 11:46 AM
  #36
Wsteun's Avatar
Is there any specific reason why someone would run weld-ins over bolt-ins? Or vice versa? Any performance reasons?
Old Feb 24, 2008 | 07:09 PM
  #37
No performance reasons, the bolt-on only work on the factory rear and the Strange brand aftermarket housings. For all other housings you will need the weld-in relocation brackets.
__________________
Allan Miller
President
BMR Suspension
(813) 986-9302
Old Feb 24, 2008 | 07:18 PM
  #38
RedLT4Mike's Avatar
My BMR bolt in brackets have grown with me from my 10 bolt to my Moser 9".
They needed a little bit to be cut off, but they are working.
I went bolt-on because I wanted to have the option to sell them when I went
9", but luckily they can still be a part of my car.
I recommend them strongly, stock or lowered.
Old Feb 26, 2008 | 06:39 PM
  #39
sidewayz28's Avatar
with the UMI bolt in relocation brackets is there any modifications you need to make so they fit? or are they 100% bolt in?
Old Feb 26, 2008 | 08:05 PM
  #40
They are a 100% bolt in, on the LS1 models all you need to do is bend out cut the emergency brake brackets.. which is very easy to do.
If you have any additional questions please ask.
Thank you!
Ryan
