Which Caliper Repair Kit?
Old Feb 19, 2008 | 06:43 PM
vMaster0fPuppets's Avatar
Default Which Caliper Repair Kit?
I'm confused on which caliper repair kit to buy to fix my rear passenger side caliper. Anyone now?
ACDELCO Part # 18K989 {#88916829}
CALIPER KIT,RR BRK DURAST0P
ACDELCO Part # 18K988 {#88916828}
CALIPER KIT,FRT BRK DURAST0P
GM PART # 18026160
Old Feb 20, 2008 | 03:43 PM
Anyone?
Old Feb 20, 2008 | 04:20 PM
robertbartsch's Avatar
I suppose it depends upon the reason you are rebuilding the calipers.
Most people who rebuild calipers do so because the hydrolic piston(s) leaks causing fluid to contaminate the pads and causing air to enter the hydrolic system. In that case, you only need the lower kit in your post above. The lower kit includes the piston seals and the bleeder valve.
Always work in pairs; do both backs, or both fronts, or all four.
This is an easy repair that only requires basic hand tools and knowledge about the hydrolic system bleeding.
If the metal chatter clips that hold the pads in place are bent or busted or the caliper slider pins are not holding grease, buy the bigger kit in addition to the lower piston seal kit.
Obviously, you will need to a bunch of new brake fliud to bleed all 4 wheels. Two quart containers should be more than enough.
Some brake pads come with new chatter clips, so if you are going to replace the pads, find out if your pad kit includes chatter clips. I've never seen a pad kit that also contains slider pin seals, however.
Old Feb 20, 2008 | 04:28 PM
wssix99's Avatar
Save the manuals!
The answer and additional details are here:
http://198.208.187.182/internet/Vehi...361!-664387115
The URL is non-descript, but its Delco's online parts catalog. You can also navigate to it from delco.com.
[IMG]file:///C:/DOCUME%7E1/GARYT%7E1.MAR/LOCALS%7E1/Temp/moz-screenshot-2.jpg[/IMG]
Old Feb 20, 2008 | 06:13 PM
So exactly why will you rebuild your calipers?
Old Feb 20, 2008 | 10:05 PM
Just my rear passenger side caliper. New rotors keep warping because the caliper is stuck.
Old Feb 21, 2008 | 04:01 PM
That is kinda hard to diagnos. If I were you, I would pull the caliper piston, replace the piston seals and also re-lube the pins and replace the slider pin seal and chatter clips.
In that case, you will need two kits. I'm not sure why kit#28 is different from kit #29, perhaps they are left and right versions.
If the rotor is wraped, you need to either replace it or have it turned (cut down) by a brake shop or parts supply house.
If it were my car, I would not do only one side.
Your axle is not bent; right?
If you know anyone who has worked on brakes and brake hydrolic systems, it would help. It is not rocket science but basic stuff like, (1) keeping everything super clean, (2) not pinching the seals, and (3) getting all the air out of the system during bleeding is critical to getting the job right.
I think the "JMX" web page for Camaros has a detailed step-by-step illustration that is helpful.
The sponsor SAM ---->
School of automotive machinists has some pitorials of brake jobs too, I think.
good luck!
Old Feb 21, 2008 | 11:08 PM
wssix99's Avatar
Save the manuals!
Amen - If one caliper is rebuilt and is better than the other, the car may not track straight in a hard stop.
