Panhard bar
Old Feb 29, 2008 | 07:49 PM
kicksZ28's Avatar
Default Panhard bar
Does the car need to be jacked up to be removed and replaced? Thanks
Old Feb 29, 2008 | 08:02 PM
Datzneat's Avatar
I jacked mine up. If it's adj just make sure you tighten when it's on the ground.
Old Feb 29, 2008 | 09:41 PM
michaelg589's Avatar
Yes. Jack the rear of the car up by the "frame". Put it on jack stands. Remove/install PHR. Lift the vehicle off the jack stands by the differential. (PHR bolts should be torqued down with full load on the rear suspension). Lower vehicle.
Old Mar 1, 2008 | 09:08 AM
kicksZ28's Avatar
Thanks
Old Mar 1, 2008 | 12:29 PM
BMR Suspension's Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Did you call the manufacturer and ask them? They should be able to help you.
In case they cannot help you, please feel free to read the installation instructions from the BMR Fabrication website :
http://www.bmrfabrication.com/INSTALL/F-BODY_PHR.pdf
All BMR suspension parts have installation instructions included in the box. Also, you can download our instructions from the BMR website. Good luck!
__________________
Allan Miller
President
BMR Suspension
www.bmrsuspension.com
(813) 986-9302
