Alignment issues Question
Old Jul 20, 2003 | 10:51 AM
SSable's Avatar
Default Alignment issues Question
I dropped my SS with the Eibach Pro kit, I put Bilstiens all the way around as well. I notice that just on the outside tread, about an inch in, both front tires tread is wearing quickly almost bald. the kit was installed about 3 weeks ago. The tires are all inflated properly. Anyone have similar issues? if so, was it your alignment or camber adjustment?
Thanks for you input!
Old Jul 20, 2003 | 03:42 PM
mitchntx's Avatar
Default Re: Alignment issues Question
You need more negative camber. It sounds like your current settings allow the tire to stand stright up under cornering, and the tire rolls underneath the car.
Take these specs to your alignment shop ...
- 0.5 Camber
+ 4.5 Caster
ZERO toe
It will be a little darty on uneven pavement, so you can't drive while talikng on a cell phone and adjusting the volume on the radio. You have to stay on top of it.
But, your tire wear will even out and you will notice a significant handling improvement.
Old Jul 20, 2003 | 04:36 PM
SSable's Avatar
Thanks mitchntx, thats what I was thinking.
Justin
