best suspension mod!
Old Mar 16, 2008 | 03:10 AM
slowjoe99's Avatar
Exclamation best suspension mod!
I already have sub frame connectors. And after the motherFREAKIN rod bolts come in finally, i will have a heads, intake and cammed motor with a 3500 stall converter. What's the best next mod for the suspension for traction?
Old Mar 16, 2008 | 03:23 AM
waldershrek's Avatar
LCA's and brackets will cure the wheel hop issue. If you can afford it I'd go with those two and a tunnel mounted torque arm.
Old Mar 16, 2008 | 03:58 AM
BlackWS666's Avatar
+1 for the LCA's.
Old Mar 16, 2008 | 04:49 AM
hpjunky98's Avatar
Best suspension mod. period. = Koni SAs
Best suspension mod for just traction = T/A LCAs, relo brackets.
Old Mar 16, 2008 | 10:15 AM
Fast_94_Z's Avatar
lower control arms/torque arm/coilovers
Old Mar 16, 2008 | 11:16 AM
jmilz28's Avatar
Best advice, period.
Or you can do your own thing and have a car that rides like crap and you'll always be chasing down problems. Good thing is, you'll never know how bad your setup is until you ride in someone's car with good shocks.
Shocks are the single weakest point of these cars' suspensions. It affects every dynamic - comfort, handling/control, traction.
Old Mar 17, 2008 | 11:35 AM
Nick D's Avatar
+1
Old Mar 17, 2008 | 02:11 PM
BMR Suspension's Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I would recommend a set of lower control arms and a set of lower control arm relocation brackets both of which we have on sale!! here is a link to our sale page-
http://www.bmrfabrication.com/taxrefundsale.htm
After these 2 basic items I would look toward the torque arms. If you have any other questions please feel free to ask
__________________
Allan Miller
President
BMR Suspension
www.bmrsuspension.com
(813) 986-9302
Old Mar 18, 2008 | 11:19 PM
FASTERthanYOU's Avatar
Panhard bar, probly the cheapest, easiest to install and you'll probly feel the most difference from it. Panhard bar.
Old Mar 19, 2008 | 12:16 AM
slowjoe99's Avatar
i just don't understand how an aftermarket panhard rod would help with traction unless the car has been lowered...
Old Mar 19, 2008 | 11:48 AM
SIC LSX's Avatar
I didnt gain anything from LCA's, but i gained a good bit with the LCA relocation brakets!
Old Mar 21, 2008 | 04:09 AM
slowjoe99's Avatar
I think the next suspension mods I will do are going to be LCA relocations brackets and a tunnel mount torque arm...
Thanks for all the input guys!
Old Mar 21, 2008 | 11:43 AM
junior28570's Avatar
+2 .. for the $$/result, relocation brackets have been my favorite mod
