Emergency Brake problems!!!
Old Mar 20, 2008 | 04:32 PM
camarostripes96's Avatar
From: Academy,Tx (home of temple/academy Drag Strip)
Default Emergency Brake problems!!!
ok u all know whenever u pull the emergency brake up u pull it hard and fast right !! well i did that the other day and whenever i pulled really hard i heard something pop and my emergency brake handle went straight up and its VERY loose and wont even tighten no more and wont hold my brakes. Well i crawled under there and the cable isnt broke but the little springs in the back drum or whatever popped off and is side ways so thats why its loose , but how do i put it back on?
Old Mar 20, 2008 | 05:23 PM
getusumws6's Avatar
pull the spring back and replace it where it goes, its pretty simple.
Old Mar 20, 2008 | 09:17 PM
CW00BlackTA's Avatar
If your spring is bent it won't ever work right until you replace it. Mine does the same thing now. I have to be careful with it, pull it up slow and towards the passenger seat.
