got a ?
Old Mar 21, 2008 | 06:12 PM
00SSog's Avatar
Default got a ?
well whenever i get on my car pretty hard a makes this noise like something is scraping the floor and i i believe its my y pipe/ my car is lowered so i dont know if that might be the reason it does that.my question is there something suspension wise that will help this or prevent this from happening.i got an adjustable panhard bar and this wkend will install my lcas with relocation brackets.
Old Mar 21, 2008 | 07:51 PM
z28bryan's Avatar
Does it sound like something is hitting under your ***? I had a problem like that and it was the exhaust piping. I can only think of that the 400 hp upgrade I got caused the rubber engine and tranny mounts cracked and wore out at ludicrous speed at that point. I had poly mounts added and the problem (mostly) went away. I put on a magnaflow catback a year later and I'm getting some exhaust banging again, so its probably my fault and I hadn't mounted the exhaust perfectly.
