Brake Booster Question
Will I have to remove the master cylinder connection to the ABS unit, or is there enough slack so I won't have to disconnect the lines?
Thanks,
John
There is enough room to just shuffle the MC over. But you will probably need to take the ABS module loose as well. No need to breech any of the lines or bleed the brakes.
The nuts that hold the booster to the firewall are under the dash. I took out my front seat to be able to get in there ... of course I'm rather robust in stature ...
Using a butterfly air ratchet certainly made things easier. I used several extension to be able just to get at the nuts and have room to work.
At a minimum you'll have to remove the coil packs in order to swing the canister out ... maybe even a valve cover. My valve cover was already off when I did it, so I'm not sure.
Having a helper is almost a must to hold it in place while you get a nut started ...
Good luck
BTW ... why does yours need replacing?
Once finished, DAMN. My car stops like a mad man.
BTW now my throttle has about 1/2 inch of slack in it, anyone have any ideas?
Thanks,
John
