Adjustable Rear Control Arms???
Old Mar 30, 2008 | 01:57 PM
sam23's Avatar
Default Adjustable Rear Control Arms???
how good are the Jegster Adjustable Rear Control Arms?? and how do u set them up??
Old Mar 30, 2008 | 02:30 PM
UMI Performance's Avatar
Can you post a link to the item you are looking at?
Thank you,
Ryan
Old Mar 30, 2008 | 04:22 PM
sam23's Avatar
here u go,
http://www.jegs.com/p/Jegster/744011/10002/-1/11177
Old Mar 30, 2008 | 04:30 PM
Originally Posted by sam23
Thank you
What I don't like about those is the rod end quality. They are using inexpensive rod ends which feature a metal ball in a metal body with no liner. They are noise and will most likely rattle.
We offer a similar set for $10.00 more however they feature a QA1 rod end with a Teflon lining. The Teflon lining prevents metal to metal contact and offers a quiet operation, they are also self lubricating. This item can be seen here- www.umiperformance.com/2016
We also have this style- www.umiperformance.com/images/2018a.jpg for $169.99 a set.
All our adjustable items are shipped pre-set to factory length and will be happy to help you set them up.
If you have any questions please ask. Thank you!
Ryan
Old Mar 30, 2008 | 04:40 PM
sam23's Avatar
yeah some told me that they are noise, but the reason im asking about them is cause i got them use from a friend for dirt cheap, and thanks Ryan
Old Mar 30, 2008 | 04:48 PM
Oh ok, I didn't know that.
To set them up lay them on top of your factory ones and turn the rod end in or out until the holes line up. Then install them at factory length
Hope that helps!
Ryan
Old Mar 30, 2008 | 04:53 PM
sam23's Avatar
oh ok thats simple, thanks again
