master cyl?
Old Apr 1, 2008 | 03:20 PM
jay_dub87's Avatar
Default master cyl?
when I push my brake pedal... it feels like i'm almost putting my foot through the floor. It's not making a grinding or squeeling noise and it's not clunking or anything... It feels like I have no brake lines.
I checked the brake fluid and it's full.
Could it be the master cylinder? Anyone else have this problem?
Old Apr 1, 2008 | 04:12 PM
robertbartsch's Avatar
Well it could be the master but it might also be air in the lines or a leaky caliper piston or two. Any brake fluid leaking from the calipers? What color is the fluid; clear or black? ANy pulling to one side?
Each season I draw out the old fluid from the brake reservor with a turkey baster. I've done this for years and it workes as a cheap maintenace precaution.
I would buy a Mityvac and bleed each wheel caliper and the master to make sure your system is not filled with air. ...cheap item at around 50 claims. Make sure you have a special line wrench or a six point for this as the bleeder screws can be rusty. Try soaking them with penatrating oil overnight. If possible, hit them with a heat gun for a minute before bleeding.
