koni part numbers
Old Apr 1, 2008 | 06:10 PM
ramsoccer11's Avatar
Default koni part numbers
what is the difference in these two?
8241-1140 Sport
30-1265 Sport
Old Apr 1, 2008 | 07:05 PM
Bow94z's Avatar
30-1265 Sport Rears are the internally Adjusted Shock (must be removed from the car to adjust) These rears are part of the Koni 4/3 package
http://www.stranoparts.com/partdetai...ID=0&ModelID=2
The 8241-1140 Sport is the externally adjustable shock which is more money since you can adjust the rear settings while the shock is mounted on the car by a turning **** located behind the rear seat carpet. These rear shocks would be part of the Koni 4/4 package
All in all you cant go wrong with either one, I run the 30-1265 rears since my needs are pretty basic and really dont need to be adjusting them all the time and they are cheaper
Old Apr 1, 2008 | 07:23 PM
Sam Strano's Avatar
LS1TECH Sponsor
Basically, that's it.... what the descriptions on my site don't tell you is that the 30-1265's have 4 detented positions, vs no detents on the 8241-1140's.
Both shocks from full soft to full stiff increase damping by about 100%. The 30-1265's do so in steps. Full soft, +20, +50, +100%. The 8241-1140's are "infinitely" adjustable within the overall range. All a matter of how far you turn the ****, and no getting "stuck" having to pick between two settings.
And fwiw, the 30's are mono-tube shocks, the 8241's are twin tube shocks (but that's really not much of a bother either way and should not be the decision maker).
__________________
Old Apr 1, 2008 | 08:54 PM
so for someone like me who doesnt autox and sees the strip mayb once a year the 30s would suffice? i just bought a set of sam's springs and didnt even think to ask...but what stiffness should i have the shocks set at?
Old Apr 1, 2008 | 09:17 PM
Bow94z's Avatar
yea the 30's are perfect for your needs. I dont autoX either and see the strip every so often, mainly cruise my car and it rides like a dream with Sams springs and the Koni 4/3 Shocks
Most guys run their fronts 4 sweeps backed off of full hard, and the rears are full soft for mainly a daily driver application.
If you have not bought shocks yet, this package is the one that best suits your needs (Koni 4/3)
