current plan for the suspension
Old Jul 28, 2003 | 12:38 PM
CHRISPY's Avatar
Default current plan for the suspension
1LE front swaybar is coming! (Woohoo!)
stock rear swaybar
front springs 1 coil cutoff
rear springs: 1.25 coils cutoff and jounce spacer removed
LCA relocation bracket
torque arm pinion angle set to -2 degrees
Total drop 1.6 inches
New spring rate after springs are cut ~320
What do you think?
Cheers,
Chris
Old Jul 28, 2003 | 01:10 PM
DARK AGE 53's Avatar
Default Re: current plan for the suspension
Chris, I'm not in favor of cutting springs but then again it's not my car, why would you want to remove the jounce spacer ? I can't see keeping the stock rear sway bar, that's why I'v ordered larger front and rear sway bars. JMO
Al
Old Jul 28, 2003 | 01:39 PM
CHRISPY's Avatar
I am going to do it in stages though. Nothing wrong with removing the spacers the SCAA guys do it all the time and pass tech. I was going to do both front and rear 1LE bars but a couple of people said not to bother with the rear...
Cheers,
Chris
Old Jul 28, 2003 | 03:17 PM
Scalpel's Avatar
Will removing the rear spring jouncer make a lot of noise over bumps, etc? PS, you owe me for letting you buy that 1LE bar so cheap!
Old Jul 28, 2003 | 03:41 PM
jd13's Avatar
I think you'll need an adjustable panhard rod to recenter your rear end since you are lowering the car. I also think your 60's are going to suffer just a tad.
Old Jul 28, 2003 | 05:57 PM
CHRISPY's Avatar
I currently have an adj PHR
Also you use heater hose on the top coil and it should be no noisier than stock.
Thanks Cannibal!! I was in a real bind!
Old Jul 29, 2003 | 07:09 AM
trackbird's Avatar
Levi....I could have used that bar....
