Brake Pad Help
Old Apr 5, 2008 | 03:13 PM
Iggz's Avatar
Default Brake Pad Help
Hey guys, I've recently been having a squeaking noise coming from my passenger rear wheel area... I had my friend drive my car slowly down the street with me walking beside it so I could figure out where it was coming from and so far as i can tell it seems to be coming from the rear passnger wheel area...
my friend thinks i need to replace my pads. The previous owner of the car changed the rotors to slotted which is the reason my friend thinks i should change my pads to get rid of the noise.. but the previous owner never told me if he changed the calipers.. i took the wheel off today and on the rear passenger caliper it said PBR made in Australia..
I have 2 questions... first, is it possible that this noise is coming from the brakes. and second.. if i were to get new pads.. would I have to order some special ones or will any regular ones work??
Thanks guys.
Cheers.
EDIT: The squeaking noise is not the same type of noise heard from SQUEALING worn brakes... just wanted to clarify.
Old Apr 5, 2008 | 03:31 PM
SS1875's Avatar
Thanks guys.
Cheers.
No special pads are needed. I use Hawk pads with my slotted and crossed drilled Powerstops. The rear calipers are stock on my 2000 SS and they are stamped PBR made in Australia . Check your rubber bushings for wear...if they look dry spray them with some warm soapy water and then test for the squeak.
Old Apr 5, 2008 | 04:32 PM
Iggz's Avatar
hmm alright i shall give taht a shot.. provided it doesn't work.. would my next step be to get new pads? when i took off the wheel it didnt seem like the rear pads were worn down very much cuz they were roughly the same length as the back plate
