Installing UMI control arm relocation brackets
Old Apr 12, 2008 | 02:09 AM
mvvette97's Avatar
Default Installing UMI control arm relocation brackets
I bought a set used so I have no instructions. These are the bolt on kind. It looks pretty easy but should I put a jack under the rearend while removing the shock bolts? I wasn't sure how far the rear end will drop
Old Apr 12, 2008 | 02:12 AM
StrobinSS's Avatar
LINK
Hope that helps a bit.
Old Apr 12, 2008 | 09:51 AM
BREWS02WS6's Avatar
What he said. That goes step by step, and if I can follow it...pretty sure anyone on earth can follow it. Dangit, thought I was gonna get to post my first link to help someone out!
Old Apr 12, 2008 | 10:40 AM
Grn4fbody's Avatar
There easy, I however did cut one side of my parking brake bracket
Old Apr 12, 2008 | 11:51 AM
BREWS02WS6's Avatar
I cut one side of a bracket too, Im guessing the same one. Everything stayed in place, I think its even in the directions IIRC.
Old Apr 12, 2008 | 12:02 PM
phantazn's Avatar
x2
i had to cut that off and grind it down in order for the brackets to fit, i also forgot to plug my passenger side abs sensor back in. whoops
