ABS Delet
4 channel option. I decided I would get rid of the ABS all together,so I got the ABS Delete kit. I've helped a friend with his kit that was on a 95 Z28, seemed pretty straight forward. We put it in and everything was fine. On mine not so lucky. With the ABS on mine the brake light stays on,ABS in-op,is on ,and a check vehicle light is now on.I know that the computer is not getting a signal so that is why the ABS light,and probably the service vehicle
light. Can I just jump these wires to trick it into thinking it has the ABS unit.
Or do I need to get someone with a HP Tuner and do it that way.Is there any one else who has done this and had the same problem. I will call up the company that I bought it from and see what they say. Just hoped that someone else did this.
