question on k-member
Old Apr 23, 2008 | 05:36 PM
gmtechnician's Avatar
Default question on k-member
i was wondering if adding a tubular k-member would allow you to remove the oil pan with the k-member still in the car? and also what brand is the best?
Old Apr 23, 2008 | 05:52 PM
leadfoot4's Avatar
I've had the oil pan off my LT-1 with the stock k-member in place. All I had to do is loosen the motor mounts and lift the engine about an inch or so.
Old Apr 24, 2008 | 02:30 AM
35th SS's Avatar
looks like the pan would drop without removing the k member.looking at mine. umi double tubed and if you remove the rack and pinion you have about 2 2 1/2 inches of room.
Old Apr 24, 2008 | 12:09 PM
3.4camaro's Avatar
You still have to jack the motor up a bit off the k-frame, even if it's tubular(Spohn). I did when I swapped rod bolts.
Old Apr 24, 2008 | 12:12 PM
Reject's Avatar
i got a bmr on mine cuss i ned the extra turbo room. i still havnt removed the pan with the new member but you have alot more room than before.and also do a search om k's cuss everyone has a different opinion as to the best one
Old May 4, 2008 | 10:51 PM
armyracer11's Avatar
Why are you needing to drop the oil pan?
