Are motor mounts worth it?
Old Aug 4, 2003 | 11:24 PM
eagle928's Avatar
Default Are motor mounts worth it?
I just put in a Prothane Trans Mount and love it so I was thinking of putting in motor mounts as well. Is it worth it? I'm not sure if I'll see the same thing with the motor mounts as I did with the trans mount.
Old Aug 4, 2003 | 11:58 PM
Jabroni's Avatar
Default Re: Are motor mounts worth it?
Describe "worth it". What are you looking for? Less drivetrain flex? If so, then yes, they will stiffen up the drivetrain a bit. If you have a cammed car with a lopey LSA, then you may get less idle shake over stockers.
