Shocks
Old May 4, 2008 | 06:08 PM
cpss01's Avatar
Default Shocks
Anyone know if these shocks are any good?
http://www.performancecenter.com/sho...uts-and-shocks
Old May 4, 2008 | 10:25 PM
95GreenZ28's Avatar
They are what I am about to order
Old May 4, 2008 | 10:55 PM
Sinister95Z's Avatar
I have had them on my car for a couple years now and am very happy with my decision to run them.
Old May 4, 2008 | 11:26 PM
cpss01's Avatar
Alright thanks for the info.
Old May 5, 2008 | 11:40 AM
lt1noob's Avatar
im also going to be using these. they arent as good as konis odviously but, for the price i beleive they are the best.
Old May 5, 2008 | 02:02 PM
sdm1234's Avatar
aren't as good, referring to what? they're not as stiff, or they don't dampen as efficiently? or do they break more-so?
Old May 5, 2008 | 05:43 PM
cpss01's Avatar
Very good. Im ordering them right now, ill let everyone know what I think of them.
Old May 5, 2008 | 07:56 PM
JD_AMG's Avatar
When you adjust the AGX's, you're adjusting the compression and rebound at the same time (so if you want more rebound, you also get more compression), with the Koni SA's your just adjusting the rebound.
If you don't understand compression and rebound you can look at howstuffworks.com under shocks. But simply put, you don't always want more compression with more rebound. More compression usually means a rougher ride(resistance to compress when hitting a bump).
Old May 5, 2008 | 08:03 PM
sdm1234's Avatar
i understand how compression/rebound works. i just wasn't sure exactly WHAT makes them not as good as the konis. thanks for the info JD AMG
