torque arm ? UMI
im running the same torque arm, and i have no complaints, i wish i could see the bottom of my car more often.
Shoot me a e-mail in 2 weeks and I will get you some stickers out!
Ryan
For the record--It was intimated that the nose of the UMI TA is made of sheet metal. It is in fact 1/8" (.125") steel plate that is cut and formed for the nose. The GM nose (according to the measurement I just took from two different GM TA's) is .110".
Not a lot of difference to be sure... but then again I don't see the noses of TA's failing, GM or otherwise. And I don't personally consider 1/8" steel to be on the same plane as what most of consider sheet metal. Technically speaking, anything up to 1/4" thickness can be considered to be sheet metal. However, there is a big difference between sheet metal that you'd see in duct work and 1/8" thick steel.
Note - I'm not knocking BMR parts here.
