brake clearance question
Old May 21, 2008 | 09:47 AM
svtwhat?'s Avatar
Default brake clearance question
ok i need to get a set of welds on my car that i have ls1 brakes swapped on. Im looking to do a 15x3.5 front and 15x8 or 9 rear but ive heard you have to grind the calipers. Do envoy calipers remedy this problem or is there any other caliper out there that will swap out to where i dont have to grind any.
if it makes any difference the car is a 87 iroc with the ls1 brakes on all 4 corners. so the offset is different by almost 2 inches too
