lightweight sway bars?
http://www.stranoparts.com/partdetai...ID=0&ModelID=7
it doesn't say the weight comparison of the front bar on his site. i believe i remember him saying his front is approximately 2 lbs heavier than a stock z28 bar....i think anyways.
right here, he says his are heavier
https://ls1tech.com/forums/showthrea...+weight+strano
good luck
For a drag only set-up run a small factory front bar (V6 car) and as large a rear bar as you can find. For a drag car the increase in weight of the heavy rear bar is not nearly as big a problem as the benefit of increased rear anti-roll. When you launch a drag car the driveshaft twists against the axle and lifts the right rear tire while forceing the left down. Running as large as possible rear bar reduces this force so you get more traction from a dig. A 24 mm 3rd Gen rear bar will bolt in for cheap. The smaller front bar allows for adequate control but with better load transfer to the rear at launch than a big front bar, hollow or not. Installing slightly longer end-links in front really frees up the travel. Don't pinch the bars to tight in the bushings, any excess friction will bind your suspension and perform poorly. Use washers under the front brackets if needed with oversized poly bushings and just get the end links snug.
Sounds like you should take a trip to a salvage yard or Ebay.
Vernon
