relocation bracket question
Old Jun 10, 2008 | 12:54 PM
cals400ex's Avatar
Default relocation bracket question
i was wondering if the aftermarket lower control arm relocation brackets replace the stock ones or are they both used? if they are replaced, i assume there is a hole in them for the brake line too?
Old Jun 10, 2008 | 01:48 PM
94'BLKBRD's Avatar
You use both brackets, but you need to cut the old bracket.....
www.installuniversity.com
Old Jun 10, 2008 | 02:15 PM
cals400ex's Avatar
i am actually looking to get bolt-on relocation brackets too if that matters any.
Old Jun 10, 2008 | 02:46 PM
UMI Performance's Avatar
Hello,
The vehicle does not have relocation brackets from the factory. The relocation brackets you purchase on a add-on that bolt to the rear end and offer lower control arm mounting locations. Please take a look at the link below and reference the picture.
If you have any questions please ask and I am glad to help. Thank you!
Ryan
www.umiperformance.com/2012
Old Jun 10, 2008 | 07:43 PM
cals400ex's Avatar
well i am glad you replied because i was going to go with umi to match my panhard bar, lca's, subframes, etc. i do have a quick question for you. do you have like a page that shows your torque specs? i need them for my bolt-in 2-point subframe connectors, lca's, and panhard bar as well. i am not sure if the panhard and lca's came with that info but i know my bolt on subframe connectors didn't. thanks again.
