QA1 setting for a vert
Rob
You need to get your ride height where you want it then adjust rebound till you get it to transfer weight till you get it to where it hooks the best,Then adjust compression till you get it to settle softly so you dont unload the rear.
Hope this helps
Doug
BTW you might want to change your sig pic before its gets forcibly removed by a mod. That thing is huge.
