Hurst line lock problems
Old Jun 14, 2008 | 08:41 PM
Gangreen's Avatar
Default Hurst line lock problems
I have had a hurst/thunder racing line lock on my car for at least a year now. I have had no problem until lately. Now for no reason the line lock will activate itself while sitting at a stop light and will not deactivate itself. It will stay that way even if you turn the car off and back on again. It will finally let go and the light will go out. I am baffled. Thanks
Old Jun 15, 2008 | 02:31 PM
Duffster's Avatar
Sounds like your wires are shorting. . .make sure there is no visible break in the insulation anywhere, maybe throw an ohmmeter/multimeter on several spots looking for grounds and worst case, replace all the wiring.
Old Jun 15, 2008 | 10:37 PM
meatman's Avatar
Yep it sounds like its just grounding itself out somewhere. Check all your wiring and switch.
