moving car without torque arm?
Old Jun 16, 2008 | 08:56 PM
ZDOG's Avatar
Default moving car without torque arm?
im swapping motors so ill have the trans out too. is it ok to push the car around without the torque arm mounted?
Old Jun 16, 2008 | 09:40 PM
ntimid8r's Avatar
Yeah it's okay to do, nothing will get damaged. Unless your pushing can create 300 or so ft lbs of torque.
Old Jun 16, 2008 | 10:00 PM
ZDOG's Avatar
depends if im drinking lite or regular. i always have more torque with regular, go fiqure!
Old Jun 16, 2008 | 10:03 PM
ntimid8r's Avatar
^^^LOL I guess you need to watch what you drink prior to moving your car.
Old Jun 16, 2008 | 10:39 PM
DanWS6's Avatar
I'm about to do the same.. and no sway bar either.. it should be.. fun.
Old Jun 17, 2008 | 07:08 AM
leadfoot4's Avatar
One thing to keep in mind, when the TQ arm is out of the car....The rear springs are behind the centerline of the rear axle. There is the possibility that their force on the axle housing could rotate the axle somewhat, causing A) the springs to fall out. This, in turn, will cause, B) the body to drop directly on to the rear axle. That could cause, C) damage to brake lines, exhaust system, and/or fuel tank.
BE CAREFULL!!
Old Jun 17, 2008 | 07:33 AM
BMR Tech's Avatar
First hand experience ....I wouldn't recommend moving it at all !!! Don't ask
Old Jun 17, 2008 | 07:39 AM
ntimid8r's Avatar
BE CAREFULL!!
That would be an extreme case to actually happen. But you're right, he should still be careful when moving the car around.
With the weight of a car on the springs combined with the lca's.....the axle housing isn't going to rotate much. Just to remove the rear springs takes some forcing of the rearend down away from the body far enough.
Old Jun 17, 2008 | 09:53 AM
DanWS6's Avatar
BE CAREFULL!!
That sounds fun. I may just put the torque arm on since my new one is relocated to the transmission mount.
Old Jun 17, 2008 | 04:32 PM
leadfoot4's Avatar
OK, let me take this a step further.... You're rolling the car a little, especially critical if you're rolling it backward, and one of the wheels "stumbles" on a screwdriver or wrench, or a rut in the garage floor. The car has a little momentum, the wheel won't rotate.......but there's always the possibility that the axle will! You know what happens next, and it probably won't be pretty.
Just be cautious is all I'm saying.
