Bilstien shocks?
For the entertainment value to wXh151, here goes:
What year Z06? FWIW, I have dynoed a lot of C5 shocks for our autox use and Bilstein HD's are actually pretty close to GM damping, and for certain year cars pretty much identical.
So while some think it's funny that I do my homework, others hopefully find my research and time worthwhile so I don't recommend improper parts, or parts that might not help much. That after all, was the question.
Handling is not "maxed out" from the factory, but a Z06 is closer than a base 'Vette with a Z51 in the middle. The fact that the stock shocks and HD's are similar doesn't mean you can't improve the dampers, it just means that HD's aren't the answer. If you think Bilstein's are the ultimate just because of the name, that'd be your mistake.
