Problem w/Hotchkis STB
Old Aug 20, 2003 | 06:52 PM
ChevyWeatherman's Avatar
master of the "jack"stand
Default Problem w/Hotchkis STB
I was working on putting some FRCs on and I took the bar off, but left the mounting brackets in place. The bolts were kind of hard to get out (I backed them out with the ratchet). I set the bar back in place, and the bolt holes don't line up! If I put the bolt for one side in, the other side is off by about half of the bolt hole. No way I can force it in. How did this happen? If I jack it up by the k-member will it help?
