problems with removing front sway bar?
Old Aug 24, 2003 | 12:16 PM
Need2gofaster's Avatar
Default problems with removing front sway bar?
I was told i need to remove the front sway bar to really get good traction. Is it safe on the street like that? I know that handling will suffer, but i really need to get my 60' times down. My traction is horrible! Help!
Old Aug 24, 2003 | 07:12 PM
2001CamaroGuy's Avatar
Default Re: problems with removing front sway bar?
its "safe" as long as you don't go all that fast (no 100mph romps on the highway ).....
really though, look into something else (eg: slicks) to get traction, having to removing the sway bar is a sure sign (to me) that the car is not set up right....
Old Aug 24, 2003 | 07:48 PM
felton316's Avatar
You will have no problem with out, just don't expect to go into corners at high speeds and keep the car level. I've had mine off for about a year now, and I've made a couple 120mph passes with no problems.
Old Aug 24, 2003 | 09:44 PM
xaon's Avatar
Removing the front swaybar is part of setting up the suspension right. Go to the track and look under the front of any of the fast cars, no front swaybar. You MUST get your weight transferred to the rear of the car and it simply just cannot do it with the front swaybar still on the car.
With that said, my swaybar has been on and off the car a few times over the last year. Now I just throw my HAL's up to about 5 and the car handles better now with no swaybar than it did when it had stock shocks and a swaybar.
Old Aug 25, 2003 | 05:31 PM
Anything else i can do to "set it up right"? Springs and HALS?
