can you help?
Old Aug 25, 2003 | 02:18 PM
snakeeater2's Avatar
Default can you help?
i have had new brakes put on my car and the rotors resurfaced and the still squeak any suggestion they will be appreciated
Old Aug 25, 2003 | 02:27 PM
mitchntx's Avatar
Default Re: can you help?
Squeak is usually pad related.
It's a very high rate chatter, from either very aggressive or very hard pads.
Anti-squeal on the backing plates will usually fix it. But it's messy ....
Many new pads come with a flexible anti-chatter "pad" that basically isolated the chattering pad from the metal caliper.
Either the tube or pad anti-squeal is available from most chain parts houses.
