Brake chatter...
Brandon.
However, I think you are causing the ABS to cycle. That will cause the pedal to pulsate and those pads have more bite than the stockers did. I'm just guessing here, but I'd say it is the ABS.
Brandon.
Brandon
The only thing I could think of regarding the need for a spacer would be if the pinion was in a different position, because the non-tcs rear ABS sensor is watching the pinion for rotation. If the guy who installed your rearend knows what the problem is, I'd say he should fix it.
Also, about the HPS pads, be careful with them. I may have a bad set or something, but I have had nothing but problems with them. I have made several sliding stops now, including almost running up a curb into a gas station the other day, because these pads like to override the ABS at low speed. At the same time, they hardly slow the car at high speed. So, you can go from barely slowing down, to having the brakes locked up, in a matter of seconds.
