Metco LCA's
Old Sep 2, 2003 | 09:02 PM
locosteelersfan's Avatar
Default Metco LCA's
I ordered the metco's with relo brackets.
Should I expect a good return as far as street
enjoyment handling/takeoff etc..??
Also thinking about an Adj Hotchkis PHR
what's the .02 on that?
I have a 99 SS, handling mods are Hotchkis SFC, SLP STB
THANKS
Old Sep 3, 2003 | 01:22 AM
1LEThumper's Avatar
Default Re: Metco LCA's
Mecto's are really bad for handling...they should be used for a drag car only...not saying you can't drive on the street with them, just don't take corners very hard. They tend to put the suspension into a bind.
If you want a control arm that does both then get some tubular ones with rod ends. If you are worried about weight, then LG has a very nice set of alum ones.
