Sophen Torque Arm (rough ride?)
Old Sep 9, 2003 | 10:13 AM
Sigler's Avatar
Default Sophen Torque Arm (rough ride?)
I have a 02 SS camaro. I recently installed an adjustable torque arm from sophen about 1 month ago. I also have lower control arms and subframe connectors with the car at stock height. I noticed after putting the torque arm on that the ride is rough. Its rough over bumps and escpecially over RR tracks (fast or slow). It feels like the car is bottoming out or somthing is banging on the bottom of the car around the rear. I made sure all the bolts were tight and it everthing was greased. Its also sloppy when your on the gas and get off the gas and get back on the gas in 1st or 2nd gear, same roughness as the bumps. Its like ther is slack in the drivetrain or somthing. I will say it did help with traction and everything it said it supposed to do when racing or drivng hard but normal driving sucks. Can anyone help?
