LCA brackets; bolt-on vs weld-in, differences?
Old Sep 10, 2003 | 07:42 PM
Turo's Avatar
Default LCA brackets; bolt-on vs weld-in, differences?
what are the pros/cons of the bolt-in vs weld-in LCA brackets? thanks!
Old Sep 10, 2003 | 07:55 PM
DARK AGE 53's Avatar
Default Re: LCA brackets; bolt-on vs weld-in, differences?
The pros for the bolt-on, they work just fine. The con for the weld-on, if there's problem or you just want to remove them you're in deep ****.JMO
Al
