Flushing Brake System
Thanks
Two man - Basically it's hook up a tube to the bleeder and submerge the other end in fluid (as to not suck up any air). Loosen the bleeder, slowly squeeze the pedal and hold, tighten the bleeder, slowly release the pedal, repeat until the air is gone or if you're doing a complete flush, keep going until the fluid is clean.
If you have speed bleeders, you can do it by yourself. Just loosen the bleeder, slowly push and hold the pedal, slowly release the pedal, repeat. Tighten the bleeder when complete and move to the next caliper.
I'd recommend pinching off the old rubber line on the wheel you are working on. Then disconnect it from the caliper, and put the Stainless line on. Then disconnect the rubber line from the hard line and hook up the new line.
Doing this will minimize fluid loss. The only reason that's important is simple--If you lose too much and let the master cylinder run dry, you'll need a LOT of brake fluid because you'll get air in everything, including the ABS pump.
When you bleed, do so from the Right rear first, then LR, RF, and finally LF. And always make sure the master is topped up.
