i need a cheap 10 bolt
well all i really need is the brake back plate, ebrake assemblies, and ABS sensors. this is for a 98-02 LS1 car with TCS/ABS. if you have a busted 10 bolt then even better. i dont even need the housing/axles/center section/rotors/calipers/caliper brackets/ etc. let me know what you guys have. i am in the Northeast texas area. DFW. willing to meet to pick up. thanks
trade huh? well at the moment i have lots to trade. i have
317 (6.0) heads/rockers/springs/valves/pushrods
6.0 cam
6.0 rods/pistons
stock F body driveshaft
stock torque arm/panhard bar/LCAs
LQ4 intake/fuel rail setup
LQ4 manifolds
hurst T56 shifter
that's all i have on the table to trade. it's just stuff i have laying around the garage at the moment. does the rear have all the brake stuff? like from the 4 bolts out? if so would oyu like to trade or i could totally give you 150 for it. where could you meet? i'm in the sherman/denison area.
6.0 cam
6.0 rods/pistons
LQ4 manifolds
hurst T56 shifter
i tell you what. you drive out to the sherman/denison area and i'll give you the torque arm/panhard bar/lower control arms/ and the heads. and 50 bux for gas. sound like a deal? what year rear is this?
