Moser 12 bolt !!
no cant go any lower cause i have the price low as i can let it go for, it is coming with a torque arm, lca relocation brackets, and there is absolutely nothing wrong with the rearend i just bought one that is bullet proof cause i am doing alot more work to the car.
sorry to post this so late but i got the rear end out this weekend and got nit all cleaned up. i have a set of wilwood brakes with the parking barke and 4 piston calipers, with a 12 inch rotor crossed drilled and slotted that i could not get off with out damaging some thing so all im asking for them is an additional 300 dollars and you have a complete rear setup. once agin sorry it took me so long for me to post this i had a sale pending but i dont think its going to work out.
when i went to put on the wilwoods i had to press the bearings off the axle to get the factory backing plates off. Moser uses a press ring to help hold the bearing on and to help pressing the bearing on, when i went to press the bearing off (which there is not alot of room between the bearing, backing plate, and the flange) the axle twisted in the press and bent the axle. and i just dont want to take the chance of hurting a perfectly good rear end just to get a set of brakes off.
no guys, he bent the axle putting the wilwoods ON. axle shaft was replaced. he doesnt want to risk doing it again to take them OFF.
But....
the next owner will have that issue to deal with if they wanna change the brakes....
But....
yes i had bent the axle befor and i had to replace it along with new bearings after i was done getting the factory barkes off, so thats why i went ahead and decided to sell the brakes along with the rear end so that why this is just a bolt in deal and who ever buys it wouldnt have to search for parts befor they got to use it
