Texas Classifieds Sell your items and vehicles here in Texas
FS: fuel system
Old Feb 20, 2010 | 07:35 PM
sr71bbjr's Avatar
Default FS: fuel system
This is the fuel system out of my street car. Has everything you will need minus injectors and rails.All fittings,lines,filter,regulator with mounting bracket,everything! I will need your stock tank and sending unit on exchange(dont care if it's 98-2002).All fittings are standard blue and red.All lines are stainless aside from the return.Regulator has a groove cut on the top where a line was rubbing on it.
2002 plastic tank with modified bucket with walbro 255 pump
-8 stainless feed with
aeromotive fuel filter
-8 to dual -6 Y(goes right on top of the trans)
-6 stainless lines that go from front of rails to regulator
aeromotive regulator with mounting bracket(mounts on passenger head)
-6 black pushlock return that routes in the frame rail and back to tank
pressure gauge on regulator
All you need is the rails and -6 male fittings that screw into the rails to have a complete system.Those that want more pump i can add another 255 walbro to the stock tank for a additional $150.
$500 plus your stock tank setup.
Old Feb 22, 2010 | 10:23 PM
sr71bbjr's Avatar
.,d,nfnadknf
Old Mar 16, 2010 | 07:11 PM
Phase-2's Avatar
will you sell just the walbro?
