2 speed Glide
Ed Anderson from A Team Transmissions built it.
High Volume Pump
Pro Tree Transbrake
forged steel clutch HUB lightened
JW SFI bellhousing
NEW deep aluminum pan
NEW TCI Turbo input shaft
NEW heavy duty stator support shaft
NEW billet servo piston with teflon rings
NEW red racing clutches and steel
REBUILT 1.76 GEAR SET
(The only used items above are the case & transbrake)
New Revmax 5000 Stall converter
$1,200.00 for everything
281-701-1909
The stall may be a little too loose for a turbo unless you are needing one to go to 5k. You can usually find nice Turbo spline stalls for $300.00 - $500.00
