WTT 347 Short block **Edit**
I have a 347 I had planned to use in a turbo build. I'm going to be staying NA for the time being so I want something bigger with more compression. Nothing fancy, just likely going to be a cam only set up.
Specs on the motor are-
•LM7 iron block bored 3.91x
•OE crank
•Eagle H beam rods with ARP 8740 bolts
•Diamond forged pistons -9cc
The motor was in a car for about 10k and was basically stock. It's never seen boost and the crank turns super smooth.
I'm looking for a 6.2 short block, though I know that's a stretch. Let me know what you have.
Buddy dropped it off while I was at work and puts it on the floor, next to the stand...
**Edit**
If anyone has a P1 or D1SC head unit that is in working order, I would trade for it. Putting together a Centri set-up would be easier than my privious turbo plans. I also have a hot side kit made by CBR that is new and has never been mounted. For the shortblock and hotside, mybe we could work somthing out.
Pic from the CBR website. I can take more and text them to you if you want.
•OE crank
**Edit**
