Fuel rail problems
Old Oct 23, 2008 | 07:40 PM
Rob_WS6's Avatar
Default Fuel rail problems
Ok im having some issues...I am installing my 92mm intake with the fast fuel rails the right side injectors are fine but when i put the injectors and fuel rails down on the left side and tighten the bolts i have a leak on every injector where it meets the rail...i have changed all the orings on the injectors and still having a major leak... does anyone know what i might be doing wrong? I've also posted this in the general maintenance section
Old Oct 23, 2008 | 08:18 PM
Rob_WS6's Avatar
nevermind guys found out the problem bolts were too tight
Old Oct 23, 2008 | 10:34 PM
OUTLAWZ RACING's Avatar
Beat me to it LOL! How do u like the 92?
Old Oct 23, 2008 | 10:53 PM
Rob_WS6's Avatar
i love it but haven't played too much bc of my front coilovers being shot going to change them out tomorrow...but just bolting on the intake and throttle body woke my motor up big time it pulls alot faster now...i'll be taking it to killeen on monday to get it tuned for the 92/92 and 150 shot...then its off to the track
Old Oct 23, 2008 | 10:55 PM
waterbug1999's Avatar
I had a similar issue with mine.. If they are not perfectly in, it tears a little chunk out of the o-ring.
Old Oct 23, 2008 | 11:01 PM
Rob_WS6's Avatar
that happened with one of them but we changed all the o rings after that and still had the issue until we loosened the bolts... no leaks dumdumdum. now just need the suspension on and i'll be happy
Old Nov 18, 2008 | 09:42 AM
maxgee's Avatar
doing the search and found this post. mine leaks on the driver's side last injector. i first swapped out all the o rings and same issue on the driver's side.
I thought I fixed it 2 weeks ago and this morning I filled up with gas and voila..leaking again. The rail doesn't sit snug on the last injector and I can see the o ring. Any thoughts?
