Tach not working/check engine light
Old Dec 16, 2008 | 09:09 PM
INVISIBLEZ's Avatar
Unhook the battery for a minute Chad, the SES light will go out
Old Dec 16, 2008 | 09:26 PM
Bad Chad's Avatar
I did, i'm leaving it unhooked tonight and I will hook it back up in the morning before I leave for work.
Old Dec 17, 2008 | 07:36 AM
rooster99ss's Avatar
you might need to just put it through a drive cycle, i'm not sure if unplugging the battery works on OBDII
Old Dec 17, 2008 | 08:04 AM
Bad Chad's Avatar
I unplugged the battery over night and the light has not came on yet.
Old Dec 17, 2008 | 09:22 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Nice! FYI: Originally, GM had planned to have a front mounted cam sensor (like the LS2 does now) and so they ran it like that. They ended up running it back to the rear for the Gen3 engines so now you have that bunk extension that MOST people wouldn't consider looking at up there on an early engine like yours (why look up there, the cam sensor's at the back???!). Glad you found it fairly quickly!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Dec 17, 2008 | 07:53 PM
Bad Chad's Avatar
I was thinking the samething... I kept looking in the back and around the fuse box but for some reason I looked there and noticed it... When I plugged it in the tack worked and the SES light has not came on since I left the battery disconnected all night...
Thanks for all the help, now i'm going to get it inspected this weekend.
Old Dec 17, 2008 | 08:24 PM
Duffster's Avatar
Congratulations on the sleuthing...
