What kind of rear end?????
Old Dec 18, 2008 | 08:38 AM
droppedls1z's Avatar
Default What kind of rear end?????
Ok I have a 63 Chevy II and its a straight six. I want to do a carbed LSX conversion but the problem I have is that the drums on the rear end are four lug. Im not sure of the gear ratio but would it be capapable to keep that rear end change the axles and the gears? Or would my other option be to just put in another rear end? What kind will bolt right up with little or no modification???
Old Dec 18, 2008 | 09:51 AM
AGRV8D's Avatar
most likely an older 12 bolt will be the best option.... do some research on what others are running, or post this in the lsx swap section on tech
Old Dec 18, 2008 | 02:48 PM
thanks for da info.
Old Dec 18, 2008 | 03:06 PM
Ls1ChevyII1963's Avatar
The stock one is a 8.2 rear. I went with a moser 12 bolt under my 63 SS. I've seen some people build the stock rear but most are forced to go with a nine inch or 12 bolt afterwards.
