Window motor/window fix Houston
Old Dec 19, 2008 | 06:17 PM
ZONES89RS's Avatar
In-Zane Moderator
Default Window motor/window fix Houston
So, my passenger side window motor is taking a ****, the driver side is off track and you have to guide it up by hand on my 95 Z. Who is a good shop on the north side to mess with this thing? I have done it before but not the window track problem so i guess i wouldnt mind having someone do both at the same time.
Any suggestions?
Old Dec 20, 2008 | 10:46 AM
ZONES89RS's Avatar
In-Zane Moderator
Help...
Old Dec 20, 2008 | 12:57 PM
Sarge_13's Avatar
I just put the drivers window back on track in my Civic. Its not hard, just take the panel off and play with the window a bit until it gets back inside the weather stripping. When you're through, its a good idea to get some spray silicone and spray it inside the stripping so the bottom part gets lubricated since its going to be real dry from there from all the water removing the lube over time.
Old Dec 20, 2008 | 02:01 PM
ZONES89RS's Avatar
In-Zane Moderator
I will just have to try it.
